- 注册时间
- 2003-3-24
- 阅读权限
- 200
- 积分
- 2115
- 帖子
- 1098
- 精华
- 1
- UID
- 1321
缩写 英文 中文
AG Automatic Transmission 自动变速箱(AT)
DK Throttle Valve 节气门(TV)
DME Digital Motor Electronics 数字式引擎控制电脑
DWA Burglar Alarm 防盗警报系统
EGS Electronic Transmission Control 电子变速箱控制系统(EAT)
EKP Electric Fuel Pump 电动油泵(FP)
EV Fuel Injector 喷油嘴
HG Manual Transmission 手动变速箱(MT)
KD Kick Down 强迫降档
KW Crankshaft 曲轴
LL Idle Speed 怠速
LLS Idle Speed Control 怠速空气控制阀(IAC)
LMM Mass Air Flow 空气流量表(MAF)
MF Microfilm 微缩胶片
MV Solenoid 电磁阀(SV)
NW Camshaft 凸轮轴
RxD Diagnosing Sensing Line 自诊闪码电路
TD Speed Signal Once Each Ignition 点火信号(CPS)
TE Tank Venting 活性碳罐电磁阀(EEC)
TI Injection Time 喷射电子脉波宽度
TL Partial Load 部份负荷
TL Load Signal 负荷信号
TR Speed Signal per Revolution 转速信号(CKP)
TD Diagnosing Data Line 自诊输入触发电路
SG Control Unit 电脑盒
U-batt Battery Voltage 电瓶供电电压(BU,BV)
U-vers Power Supply 系统供应电源(PW)
VL Full Load 全负荷
OBC On-Board Computer 随车自诊电脑
RPS Rollover Protection System 翻车防护装置
EML Electronic Engine Power Control 电子引擎功率控制
LKM 灯泡烧毁监控器
TSH 中控锁自动加温系统
FH 中控电动镜
ZV 中控锁系统
SM/SPM 电动椅/电动镜记忆系统
SHD 电控天窗
SRA 大灯清洗器
K/CC 仪表资讯简易自诊
IB 车内灯光控制器
IHKR-F3 电脑恒温系统
BMW Abbreviations
BMW Abbreviations and Acronyms
Throughout your career as a BMW Group Service Technician you will come across many acronyms in the various Technical publications. Even
BMW is an acronym. An acronym is a word formed from the initial letters of a longer word. These are a list of acronyms describing various
systems on BMW Group automobiles and SAVs.
Remember this is only a partial list. The BMW Group is a dynamic company and is always adding new systems to its products. Look for new
systems and acronyms with new Technical Training courses, Service Information, and Technical Information Bulletins.
A Processed Vehicle Speed
AB Airbag
ABS Anti-lock Braking System
ADS Engine Intake Air Control
ADV W/wiper Pressure Control
AGS Adaptive Transmission Control
AIC Automatic Interval Control (rain sensor)
ARS Active Roll Stabalization
ASC All Season Traction
ASC+T ASC+Traction
ASK Audio System Controller
AST Slip Control (Marketing term)
AUC Automatic Air Recirculation
B Benzene (gasoline)
BC Board Computer
BC1 Body Controller 1
BLS Brake Light Switch
BMBT Board Monitor
BS Block Diagram
BST Battery Safety Terminal
BZM Center Consol Control Center
CAS Car Activation System
CBC Corner Braking Control
CAN-BusController Area Network(bus)
CCM Check Control Module
CIM Chassis Integration Module
CVM Convertible Top Module
CVT Constantly Variable Trans.
D-Bus Diagnosis Bus (same as TXD)
DBC Dynamic Brake Control
DCS Dealer Communication System
DDE Digital Diesel Electronics
DIN German Industrial Standards
DIS Diagnosis and Information System
DISA Differential Air Intake Control
DK Throttle Housing
DKI Throttle Position
DM-TL Diag.Module Tank Leakage
DSC Dynamic Stability Control
DSP Digital Sound Processing
DTC Diagnostic Trouble Code
DWA Theft Deterrent System
DWS Tire Pressure Warning System
EBV Electronic Brake Proportioning
E-KAT Electrically Heated Catalytic Converter
ECM Engine control module (SAE)
EDC Electronic Dampening Control
EDK Electronic Throttle Valve
EH Electronic Hydraulic
EHC Electronic Height Control
EKM Electronic Body Module
EKP Electronic Fuel Pump
ELV Electronic Steering Lock
EM Electro-Mechanical
EME Electro-Mechanical Emergency Brake
EML Electronic Motor Load Regulation
EO Component Location
EPC Electronic Parts Catalog
ETM Elec. Troubleshooting Manual
EWS Electronic Driveaway Protection
FB Function Description
FBZV Radio Frequency Locking
FRU Flat Rate Unit
GAL Speed Dependent Volume
GM General Module
GMR Yaw Moment Control
GRII Cruise Control
GPS Global Positioning System
HDC Hill Decent Control
HFM Hot Film Air Mass Meter
IB Interior lighting Control Signal
I-Bus Information Bus
IHKA Automatic Heating and A/C
IHKR Regulated Heating and A/C
IHKS Standard Heating and A/C
IKE Instrument Cluster Electronics
IR Infrared
ISIS Intelligent Safety Integration System
ISN Individual Serial Number
KAT Catalytic Converter
KATON Converter Heating (signal)
K-Bus Body Bus
KL Terminal Designation
KO Compressor "ON" Signal
KOMBI Instrument Cluster
KOREL Compressor Relay Signal
KW Crankshaft
LCM Lamp Check Module
LDP Leak Diagnosis Pump
LEV Low Emissions Vehicle
LKM Lamp Control Module
LL Closed Throttle
LRA Vertical Headlight Aiming
LSM Steering Column Memory
LSZ Lamp Switching Center
LVA Air Supply System
LWR Vertical Headlight Aiming
LWS 5 Steering Angle Sensor
MBC Maximum Brake Control
MDK Motororized Throttle Valve
MFL Multi-Function Steering Wheel
MEC Multi-Function Controller
MID Multi-Information Display
MoDiC Mobile Diagnostic Computer
MRS Multiple Restraint System
MSR Engine Drag Torque Reduction
NG New Generation
OBD On-Board Diagnosis (SAE)
PB Pin Assignments
P-Bus Periphery Bus
PDC Park Distance Control
PWG Pedal Position Sensor
RDC Tire Pressure Control
RDW Tire Pressure Warning
RM Relay Module
RPW Tire Puncture Warning
RXD Wake-up Diagnosis Line
RZV Direct Stationary Ignition
SB Fuse Assignments
SBE Seat Occupancy Detector
SCA Soft Close Actuator
SG Control Unit
SGS Seat Integrated Belt System
SHD Sunroof Module
SII Service Interval Indicator
SM Seat Module
SP Schematic
ST Connector Views
SZM Central Switch Center Module
TD Engine Speed
ti Injector on time
TL Part Throttle
TLEV Transitional Low Emission Vehicle
TRS Battery Isolation Switch
TSH Door Lock Heating
TU Technical Update
TXD Transmitting Diagnosis Line
VANOS Variable Camshaft Timing
VL Full load - wide open throttle
WK Converter Lock-up Clutch
ZAE Central Airbag Electronics
ZGM Central Gateway Module
ZKE Central Body Electronics
ZV Central Locking System
ZVM Central Locking Module
ZWD Idle Control Valve
